Go Back   DIY Go Kart Forum > Building Plans And Advice > All Other Parts
Closed Thread
Old 08-11-2016, 10:31 PM
Bbqjoe Bbqjoe is offline
Banned
Default A do it yourself cable end that works. (Updated)
I tried just about everything there is on the hot side of things. Of course lead won't stick, and it's too soft anyways.
I tried a quick zap with a wire feed welder, and the cable just went up in smoke. I tried the one off of youtube where the guy melts silver solder into a hole drilled in wood and dunks the cable into the solder until it solidifies. I did it, but it failed a day later when my friend cranked the throttle on my bike.
The closest I got was wire feed wire, and oxy-acetylene. I got a nice solid ball on the end that might have worked, but it was crushable in a vise.
I tried hot glue. fail.
Someone said JB weld, but who wants to wait for that to setup? I want to ride!
My buddy and I were in my shop. 4:20 had come, and we spent a few minutes thinking this one through.
We finally found the answer!
It's so simple it's stupid, and it will never come off unless it's cut. Besides that, it fits the mikuni carb cable set up perfect!!!
Would ya like to know what it is?
Would ya?
Yes?
PM me for my address, send $4.95 and a self addressed stamped envelope, and you will know the answer to life, the universe and everything when it comes to installing your own cable end!!!
Or...You could wait until tomorrow, when I post a free "how to do it" video.
Mail now, or stay tuned!!!
Or watch now.
The Following User Says Thank You to Bbqjoe For This Useful Post:
Hellion (08-12-2016)
Old 08-11-2016, 11:05 PM
chancer's Avatar
chancer chancer is offline
ɔ ɥ ɐ u ɔ ǝ ɹ
So this video was made just after 4:20?
I'm staying tuned. LOL
Why don't you, go back to your double wide and fry something!
Old 08-11-2016, 11:16 PM
Banned
Si Senior.
Old 08-12-2016, 06:18 AM
ezcome-ezgo's Avatar
You tied a knot in the end.
Old 08-12-2016, 07:04 AM
Poboy kartman Poboy kartman is offline
Banned
Quote:
I had that same thought...but didn't want to say anything. It's either that...or something ridiculously complicated.
Old 08-12-2016, 07:09 AM
I had a problem with the line on my trimmer coming out of the head. The little toothed pawl in there wasn't grabbing the line and resisting the centrifugal force. I took that trimmer head apart a half dozen times trying to get it to function as it should. Finally just tied a knot in the line on the inside of the head. Works like a charm.
  #7
Old 08-12-2016, 09:14 AM
mckutzy mckutzy is online now
Did you clean, flux and tin the cable before using solder?
I have had the same problem with the ends, for them not to fray.... They need fluxing well.
  #8
Old 08-12-2016, 02:49 PM
Hellion's Avatar
Hellion Hellion is offline
Disc brakes'r for cowards
Quote:
Originally Posted by Bbqjoe View Post
...I tried the one off of youtube where the guy melts silver solder into a hole drilled in wood and dunks the cable into the solder until it solidifies. I did it, but it failed a day later when my friend cranked the throttle on my bike.
Is this the guy and the method? Just wondering because the results seem to be quite effective. The second part at 6:30 is for a heavier duty cable end like we would use.
  #9
Old 08-12-2016, 04:56 PM
chancer's Avatar
ɔ ɥ ɐ u ɔ ǝ ɹ
C'mon Joe it is after 4:20
Where is the Video?
  #10
Old 08-12-2016, 05:09 PM
Russ2251's Avatar
Russ2251 Russ2251 is offline
AZUSA:Powered by LAWN-BOY
Applying heat will set it in just a few minutes, not hours.
https://www.youtube.com/watch?v=c4jch0puM1A
  #11
Old 08-12-2016, 11:43 PM
Banned
Sorry guys I wanted to make the video today, but ran out of light once I had time.
I'll do it tomorrow.
  #12
Old 08-13-2016, 05:14 AM
Denny Denny is offline
Lay off the 420 and you'll have time!
Old 08-13-2016, 06:22 AM
DeathMachine's Avatar
DeathMachine DeathMachine is offline
It's always 4:20 somewhere!
  #14
Old 08-13-2016, 01:16 PM
Banned
Here you go guys!
Poboy kartman (08-13-2016)
  #15
Old 08-13-2016, 01:21 PM
chancer's Avatar
ɔ ɥ ɐ u ɔ ǝ ɹ
Oh this is great. Especially at 30 seconds to 53.
Must here Also from Joe
The Following User Says Thank You to chancer For This Useful Post:
  #16
Old 08-13-2016, 01:34 PM
Banned
Don't you just know if Joe and I got together for a day....civilization as we know it would cease to exsist....
I'm still wondering why he didn't use the mechanical rat trap behind him in this...could saved a step.
Just put cheese on the end...and a sign in rat language that says: "This way out." No crimpers needed...but you'd still need the pipe wrench.
The Following User Says Thank You to Poboy kartman For This Useful Post:
chancer (08-13-2016)
  #17
Old 08-13-2016, 02:12 PM
Banned
Quote:
I fondly refer to that as the club. When closing up the shop for the evening, I usually announce the night's specials. The mice love hearing what's for dinner.
It will probably be free ritz cracker night tonight.
  #18
Old 08-13-2016, 02:30 PM
bob58o's Avatar
bob58o bob58o is offline
The Independent Variable
Poboy is Youtube Famous!!!!
There are two types of people. Those who can extrapolate from incomplete data
  #19
Old 08-13-2016, 02:33 PM
Banned
Quote:
"Fabulous! " Jeeze...bartenders can't spell!
  #20
Old 08-13-2016, 08:23 PM
Banned
What? Is there only like 8 people on this entire board???
Closed Thread
