welding
RobertD
Administrator
Texas
not if you've welded properly.
You grind welds in order to get rid of the extra material that doesn't sit flat on the metal. To "pretty them up". This isn't a problem if you got plenty of penetration on your weld. If you didn't use enough power, then that is your problem, not the grinding that made the weld weak.
