Vermont/NH/MA folks, free engines and parts
Kaptain Krunch
Pro Junk Collector
vermont
FREE FREE FREE
Its spring cleaning time! thought i'd throw this out to you guys before i send it off to the scrap yard. I have a pile of misc engines, some could be saved, some are good for parts. ALL FREE. Going to be digging more out within the next few weeks, but heres what i know i have as of now:
2 - 5hp flathead briggs, One comes on a rototiller, runs but burnt a lot of oil, other ran but has a cracked intake (block, not runner)
2-3 - old tecumseh snowblower engines, 5-6hp, turn over probably need carbs (points?)
1 - Honda clone engine, came off snowblower...not sure what size, it ran but coil, blower housing, carb and fuel tank have been stolen
1- Suzuki 250cc quad engine, no electronics, carb or exhaust, stole a million bolts out of it but its complete otherwise and supposedly ran when removed.
1 - Briggs 208cc OHV engine...somewhat complete, the governor gear pin sheared off, engine ran when pulled but would not work for its intended use with no governor. would need to be re-assembled, some parts are missing, recoil, hardware, muffler potentially.
1 - 8hp flathead briggs and stratton, attached to a generator (tapered shaft) Missing carburetor, ran otherwise.
1 - 150cc GY6, stuck valve, missing all accessories shrouds electronics etc...sat outside all winter, has reverse.
There will be more, as i clean and i will update.
ALL FREE to forum members, but i will not ship, or drive to you.
Located in central southern vermont, near killington.
great offer Kaptain!
May I STILL remind the now deleted friends of ours..
to read about this forum's rules
So if - for whatever reason - you do not want to get the parts offered
then please keep that to yourself.
If you have sincere questions and are willing to drive/fly/swim to vermont to pick up
whatever Kaptain has to offer..
then AND ONLY THEN!
feel free to ask.
Kaptain Krunch
Pro Junk Collector
vermont
Update and bump, will be scrapping within the next 2-3 weeks.
additional items:
-Suzuki mini 3 wheeler...pretty beat, ran a year ago but had low compression, blew a tire out and it sat ever since. 50cc 2 stroke.
-Old ford garden tractor, no engine, good transmission pretty rugged unit.
-1960s 10hp outboard engine, it has been stripped down to just the engine, cases cut off. it ran a year ago. 2 cylinder two stroke, very compact...no idea what it could be used for.
-ATV rear end, shaft drive with locking differential, drum brakes, removed from kawasaki bayou 2wd i believe.
-Honda GC160, horizontal shaft off a pressure washer. ran a year ago, has a short 7/8 crank i believe.
Budget GoKart
Aka a kenbar
roachdale, indiana
I understand the no shipping part, but my question is does the 5hp with the oil issue run well? because (personally i would pay you to ship it but i understand rules.)
