Hi, I have a built 196cc clone. Its a mod2 cam, billet rod and PVL flywheel, champion rockers and head is shaved. I noticed a lot of oil coming out of my stock breather before I switched over to champion rockers, and I want to do some venting. I originally thought maybe my head gasket wasn't sealing, because it was a decent amount of oil, but I took the head off and everything seems fine (no marks from combustion or any leaks)
I am going to be buying a champion valve cover, the one that has more clearance for the rockers. As I said, I want to do some venting to my engine, but I'm not sure how to go about it.
If I drill and tap the valve cover, will there be enough material for me to screw the fitting in tight? Should I use Teflon tape or high heat epoxy on them?
If the valve cover already has a one way valve in it, can I use that for my crankcase vent to a catch can and just run the lines from the valve cover straight to the engine side cover?
