Got a little done this evening around other obligations. Stuck together the basic frame for the engine to mount on, and started on the motor mount plate. I made it long enough that I can mount both the engine (with TC on it) and the FnR box behind it. Got dark on me so I snapped some pics and called it a good day.
My roll of chain and chain breaker were lost in shipping. They were supposedly, according to Amazon, delivered to my local post office on the 25th and have been "running late but still in transit" after being "checked in" at our little two-man operation with one rural route and like 40 boxes. Yeah, right. What happened, I suspect, is that my box fell out of the bin it was being transported in on the Amazon delivery truck, and wasn't noticed until later, then was pitched into any random handy bin still in the truck and delivered to a post office somewhere within several hundred miles of here. I trust these guys here in my local post office, known 'em for years, they LIVE HERE, they wouldn't b.s. someone. I don't think the box ever left the truck in Mountain Home, Texas. Long story short (if that's possible at this point
) I did get ahold of Amazon who did cancel and refund, and my 2nd order of stuff I was counting on having yesterday for this weekend, well it'll be here Tuesday. Maybe.
Was thinking I needed the chain before doing any more puttin' together of stuff, but not really. I can straight-edge off of the TC's backing plate and square up the FnR box, and with the 1 1/2 inches of slide I built into the engine, I can adjust the chain on that end. The input shaft of the FnR box is long enough where so long as I get the thing square with the engine, I have enough leeway to slide the sprocket enough to line stuff up when the chain gets here. I'll be stuck after tacking things until I get chain and hook it all up and do a live test up on jackstands, though, until probably Wednesday at the earliest (since this time the order is coming UPS and they get here about 6 pm.)
Plan is to tack everything in place and set it back into the buggy, then build the pillow block mount off the axle. I'm pretty sure I've got the room to take up slack in the back chain (from FnR box to axle) with an idler in the return side when in forward gear. I don't know how loose I'm going to have to leave that one to account for the suspension. Probably not too terribly loose, as I'm going to block the springs quite a bit from where factory stops are. Maybe a piece of 2" square tubing as a spacer to shorten the distance from unloaded to spring stop. Might ride a little rougher with a load, but oh well. Might eat a chain under load, if that's all it does, I'll know better than to load it that insanely. Might also find some way to engineer something springy of some sort into the idler and make it into a tensioner. (I can Rube Goldberg with the best! LMAO)
Not too many pics for today, just two, of work done. Peewee spent his Saturday lounging in the shade and 'supervising' from afar; he didn't do anything interesting or photogenic today!
That's a piece of 3/16" flat plate that came with this place. Found it under a couple inches of oak leaves under a tree in the front yard. It's in one of the pics of the drops and scraps I have at my disposal to create this Frankenstein. I cut it 6" wide and 19" long; most of the ready-made ones are 5x14 or so, and <1/8" thick. I should be okay.
The square tubing piece under the back of the motor mount is nothing more than a spacer to give me an idea of how and where the mount plate is going to ride. Gonna put a couple of little short ape hanger style ears on the front (nearest camera) to ride on the frame rails to hold the front of the plate down, I don't know if it'll have enough torque to pick itself up with a load in it or going up a bit of a hill, but I sure don't need the seat goosing me!
Yeah, I use all Harbor Freight and Hyper Tough tools. I have for 25 years. Well, HF and Walmart, whatever store brand they had at the time I needed something. Have had good luck, especially with the latest incarnations of HyperTough and Warrior brands. And of course Predator, that's one heck of a good line they have. I've got an old generator that's so old it's BLUE but has a Predator engine. Last time I started it up it was one pull and settled in like it was new. I think I bought it in 2005... 5500 watt. Ran like a champ through Harvey in '17 when we rode that one out 5 miles from its first landfall in Aransas County, and then again in '21 through the Valentine's ice storm... Nothing bad I can find to say about either place's quality of stuff. Sure it's not Snap-On or Mac, but don't abuse it and it'll do what you need to do. </soapbox> ....and no, I don't work for either place....
