Tires
cook47
Vetran with Karts
alaska
Hey new and I have yerfdog 3203 stock everything... and I was wondering how my tires look like this? where can i get some more cheap ones? also as I said the motor is all stock- a 6.5 horse techumseh... what are some upgrades to the motor and the kart? anything... and 3 last questions... 1. How can i take of the exhaust and put a straight pipe one on? 2. Where can I buy a straight pipe without welding and etc...3. is it possible to put an airfilter on there like a k&n one? thanks!!!!
JH Pinoy
By looking @ those tires I can tell ur using them on road. Tell me the rim and tire size and I can help u with that. FYI, Also if you do try to upgrade ur motor like installing new muffler and air filter it wont make you go faster, it will only make you start out faster but the results will be minimal because of the engine size ( 6.5 hp).
Blazkowiez
Kart Aficionado
Houston, Texas
I will note that unless I read something wrong the links you gave him are for clone parts and he is running a Tecumseh.
jareeB
hey he puts a pipe and a air filter on he WILL need to rejet so he doesnt lean the engine out and burn it up
cook47
Vetran with Karts
alaska
So guys how do i put an airfilter... Ok also how can i take my tires off??
Air filter- follow instructions provided with kit.
Tires- remove wheels from kart, depressurize, break bead, pry off with flat bars or large screwdrivers. In fact, do a search- Blazkoweiz posted a lovely video on tire changing.
Redline-Go-Kart
Kart Master
Mesa, Arizona
I think he means taking the the tire of of the go kart
r97
Measure twice cut once
Massachusetts, USA
:iagree:, make sure the parts you order will fit you engine. considering they are two completely different engines the specs could easily differ.
