I know how the timing works and that I can file the keys myself, but what I asked is what keys people have used an had success with since they are sold in a wide range of advance.![]()
Advance Timing
Once you remove your flywheel and tap the timing key out of the crankshaft, you can measure the thickness of the key. You should get a similar measurement to what we're getting here. Our key is .160" thick. Our goal is to advance our timing 8 degrees. We know every .006" we file off the key...affordablegokarts.com
File it yourself.
No. I just tightened it up like I have done on other Predators.did you torque the flywheel to spec?
I don't think they are damaged. I put the stock key back in and it runs fine.well that could be your problem. you may also need to lap the shaft and flywheel if either are damaged.
