Millwright
- Messages
- 115
- Reaction score
- 28
Well I have just about had enough with this throttle issue!!!
Made a couple silly mistakes due to trial and error.
I believe the governor spring is causing problems.
It takes a fair amount of force to get the lever to the full speed position, then it won't return to idle on its own. I needed to add a return spring, of course that's just adding to the force required to get to full speed. Add to this the resistance in the cable itself!!!
I took the governor off!!! It should be easier now.
I wanted to leave the governor on for a while to do some expirementing and baseline setting for stage 1 upgrades.
I'm just running on jackstands right now, but man what a difference with that governor removed.
