Pro Procrastinator
I wasn't sure where to post this thread. I almost put it in "Engines and Clutches' but just decided to do it in here.
Now to my actual question:
Does my gas pedal have to have a return spring on it? I bought Azusa pedals from Amazon and they came with return springs...However the springs require a bit of welding to install (at least on my frame) so I'm wondering if I can just not bother with them things. Will the spring on the throttle arm be enough to do the job? If I unscrew the 10mm nut that holds it down some more, will it have enough power to pull the pedal back up?
I don't wanna be that guy who gets in, floors it, and then the gas pedal won't come back up after it's gone down .
