this thing followed me home i swear.
jmaack
Another curb alert pressure washer. Started on second or third pull. Fuel pump must been dry. Oil was fairly clean pump oil was nasty didn't look like it mixed with water. But here goes. Had pressure only ran for a minute or so then pulled pump off to clean and check for other leaks.
Just sprayed down with degreaser and used garden hose for now. Lucky me 3/4 shaft finally.
Not a good Gokart engine unless you are trying to kill yourself with carbon monoxide. Muffler points the wrong way. Better as a pressure washer than anything else.
jmaack
lmao. if I decided to use it for a toy I'd make a new exhaust. Just gonna flip on marketplace. I wish it were a manual throttle kind but again for the third time screwed.
Easy flip as it is.
