Plan B is fire and an EZ-out.
Sounds like you have a hard case. Try the above, then just replace it.
Torks are non-binary, they are mostly SAE but some identify as metric. They might have pronouns such as mm or .xxx or just plain T. They are a confused lot.But why is there metric and sae Allen but only one in torx
We need more details. Did you get it apart or resort to replacing the whole mess?I have a new hub
It has what looks like a new motor. I replaced the front wheels and the clutch. I am trying to do a full restore but I dont know exactly what brand or model this is. Any help will be appreciated. Thank you!
That is not right the way it is set up.
....I replaced the front wheels and the clutch. I am trying to do a full restore but I dont know exactly what brand or model this is. Any help will be appreciated. Thank you!
That was the plan. Not a full restore. But to make it look good. Finally got the RR hub off. I have a replacement hub but need a new tire and tubeBe careful with your tire pressures. The (Turf Saver) front tires in the front are supposed to have a square-ish profile and should not be rounded like that. It looks like they have about 2 or 3 times over the allowable tire pressure....
Full restore? That means a return to original condition (and that's nuts!). I don't think the original had skulls or those nerf bars on the sides, nor any diamond plate. Just tidy it up, paint over the bare metal make it look halfway decent and DRIVE.
im watching the tire wear and it definitely looks like i need to drop the pressure down a bit to make more of an even wear. Thank yall for all of the info. i plan on using the stock wheels, (sanding them down and repainting them). Looks like they are a two piece wheel. Any ideas on where I can find a decent (inexpensive tire and tube)?That was the plan. Not a full restore. But to make it look good. Finally got the RR hub off. I have a replacement hub but need a new tire and tube
