Millwright
- Messages
- 115
- Reaction score
- 28
So I got an "off brand" 40 series TC, and a Honda clone "Power Fist" engine.
Couple of issues.....
On the TC, the driver pulley has a 1" bore with an integral key machined into it. The Key seams to be undersized as there is a lot of play when it is slid onto the engine shaft. I'd say several degrees of rotation, plus the key is not tall enough. I'm sure that under load, the key would just fold over.
The keyway ( 1/4" ) on the engine shaft is correct, I checked it with other keyed components.
The problem with the engine, is that the shaft is too short by 1".
So I plan on welding on a shaft extension, and then bolting the TC on, and then putting a small weld to lock the TC to the shaft so it can't spin and overload the loose key fit.
Any other suggestions?
