Surface prep / blasting tools
gegcorp2012
Alabama
What kind of rig do you have for surface prep like stripping rust and old paint etc?
I decided to get a power washer attachment to draw in some sand blasting media (wet blasting) and tried it the other day but the bag-o-sand I had was too wet and I was not able to use it as I had planned.
I think this may work OK with really dry sand, but if there is a problem with the moisture in the sand - the whole rig is useless.
I wanted to see if anyone else is having good results using water and abrasives together (dustless blasting outside or vapor blasting in a cabinet).
What you got ?
