Super Easy Predator 420cc Throttle
Joe-405
Enjoying New Projects
U.S.A.
Seen a lot of questions about it so here is the easiest I’ve found..............
And with full governor removal also !
the rod was bent from the stock one that comes off. I did not use any pieces that was not factory oem after removing the governor.............
the throttle cable is temporary with the zip ties but you can literally put it multiple spots other than where mine is.
Joe-405
U.S.A.
Final design and throttles cable bracket made out of the old governor arm ! So no extra parts used anywhere still.
Big Bob
So you pulled the governor or basically just by-passing it? When you pull the governor the stock throttle stuff is all gone. And you don't want to over rev the engine as the flywheel can grenade on you. Ditto with the connecting rod.
