Steering
Robert.jones10
Hi. I'm new here. So my dad got ahold of an old yerf dog kart. Model #3202. So I guess the question would be is, what would be the right size steering rod? The one that connects to the axle?
I would say that the rod that needs to be replaced connects to the right of the axle(so the passenger side).
Brianator
Gettin' er done!
Barrie, Ontario, Canada
You'll get the best help if you post a couple pics, someone might spot something that's been overlooked and if not... we still like seeing pics of peoples projects! :cheers2:
Howdy :welcome2:
It sounds like the part your needing a called a "tie rod" :thumbsup:
...which is a usually a (5/16" or 3/8") rod with threads on both ends
...& then, has a "tie rod end" threaded on each end
One end connects to the steering shaft
...& the other connects to (1) of the spindles/wheels
Here is a manual for a Yerf Dog 3202 :cheers2:
http://www.bmikarts.com/PDF/3202_D.pdf
The right tie rod is listed as (Tie Rod Right 20") part #94, on page 16
...& you can see it on the "blown up" diagram, on page 17 :cheers2:
