Newbie question on a steering issue we're having.
We recently bought a go kart that requires some work, and I will include pictures to hopefully make as much sense as I can. The issue we are having is the front right wheel is lifting off the ground when turning to the left. I initially thought there was an issue with the tie rods, however once I removed them and turn the wheels independently, the front left wheel is definitely lifting up as you turn it left.
The first pic, is the current setup, no tie rods attached and the wheels are fairly straight.
The yoke that holds the king pin is welded onto the frame at what appears to be the same angle as the offset of the kingpin and hub assembly. Somewhere in this configuration though there must be an issue. The 3rd pic shows the kingpin yoke from the top looking down, and it is welded onto the frame on a lean, top to bottom.
I have seen many configurations like this, but am wondering if this could be causing the issue?
The steering is very difficult at best which is the first problem we are tackling, but the major issue here is that when turning (Left only???) the right wheel comes off the ground. I do believe there is a slight lift on the opposite side when turning right, but it almost not noticeable.
The frame is square, the kingpin yokes are mounted evenly. Really just looking for advice. Thanks in advance.
