So looking through azusaparts.com at their sprocket hubs, getting the correct pattern doesn't seem to be very straight forward. Currently I have a steel 60 tooth sprocket for a 1" live axle, however in my short sightedness, I neglected to think of sprocket replacement, either for gear ratio changing, or in just needing to swap out a sprocket because it has worn out. So I've been looking at doing split aluminum sprockets, and in doing so I'll need a hub.
Now when looking at their sprocket choices, you have the drop down for various different bolt patterns for hubs. The numbers they give with them, you would think would match up with hub part numbers. But when I click on them, the part number is not found.
So I tried Go Power Sports, since I know a lot of their supplies come from Azusa, I figured well maybe they might have a suggested sprocket for said hub, or vice versa. Nope. Is there an easy way for a novice to pair up a sprocket pattern for a hub bolt pattern?
