DMCdesign
Master Apprentice
lets have a short debate on go kart build materials. Let me begin with a few words- steel vs. Aluminium vs. Carbon fiber- which will win?
If I had won the lottery, Id buy my Lamborghini Aventador LP 700-4 for sure, Id also still be here building alongside y'all DIY style.
Isn't that one of those things that cost like $500 for an oil change, ~$5000 to $6000 for a brake job, and has the luggage space for a couple of vinyl graphics????
Im not entirely sure for a lambo, I do know that a front right brake for a Ferrari I think it was a 458 Italia, which was one of those neat-o carbon/ceramic thingamabob jobbies cost about........$4500 new......... used(previously enjoyed, gently caressed and massaged)is about half.......each rotor........ No pads/shims ect.(pads about 1600-2k) Calipers are about the same $ as rotors, front(s) more expensive than rears...
Ya a bit excessive, but hey, I might get some of those same fancy brakes for my bike aswell.. what the hey....
oh to have the luxury......
Could be worse, a set of tyres for a Bugatti Veyron costs about the same as a new small car...
Steel is better, and here's why; Yes carbon fiber might have a stronger tensile strength.. But if and when it does break. Carbon fiber part has to be REMADE from all new materials. While steel, you can simple un-weld the section. and re-weld a new piece, without the need to rebuild the whole thing again. I believe carbon fiber is this strong only in a directions tangential to fiber flow. In direction perpendicular [which is how a force would be applied in case of bullet impact] it is not as believable. steel would again have better quality's over carbon fiber.
some aluminum are good alternatives between carbon fiber and steel. because they can be strong, but also save weight, it's the good middle man. also the good aluminum can be heat treated and hardened.
Comparing weight to weight, asbestos is "safer", comparing surface area to surface area, they have roughly the same severity of health effects.
