Spiderbox starting issue.
Builds4Christ
Hey all,
So I recently got this engine started and running, but am having trouble with initial start and restarting.
I connected the autochoke on it incorrectly initially. I didn't realize it needed the resistor in the circuit and I'm still uncertain as to whether or not I wired it correctly.
So I initially wired it in to 12v without the resistor and was having some trouble starting. Now, it wont start if I have the choke plugged in. I have to unplug to get it going. before rewiring with the resistor, it ran good at WOT, but now it bogs. I tested to ohms through the resistor and its about 9.6 ohms, which I think is good.
Idk, maybe I wired the resistor in wrong. It's on the positive wire. The other thing was I wasn't sure about was which wire on the choke was the positive, but with the limited info I was able to find, I chose the yellow.
The cart has issues starting but dang it I can't figure it out yet. Valves are adjusted btw and all the other parts are new (but ****ty amazon part lol).
Another weird thing. So after I run it for a while and it doesn't want to start, it WILL start if I connect my 40 boost charger to it. The battery is brand new and it's done this through two batteries. Both batts were good, but I just wanted a larger one.
I'm beginning to wonder if its a spark issue too. IDK.
JUST checked voltage at the battery while it's running. 12.18vdc. Not good! Wth is going on?
Any guidance would be appreciated!
Should have like 2 or 3 wires coming from the stator, i think they are yellow(?). Those are your AC power wires. Are you getting voltage there? Next in line would be the voltage regulator. Box with heat sink fins on it. Pull a schematic and see if that's functional.
I don't know that model but just talking general kart wiring.
You might not be charging and just draining your batteries. Low voltage can cause weird problems.
