Solved
G.W
Nyssa Oregon
Pull off the belt cover and check your drive belt and clean and relube your clutches. It sounds like your drive belt is fried. Replace it with a Genuine Comet Belt Only! Go to the GoKart Supply web site for belts and CVT instructions. Good luck!
I believe he has a centrifugal clutch. The Baja I had had a centrifugal clutch. It sounds like it could be a clutch issue or a carburetor issue
G.W
Nyssa Oregon
It's hard to tell if you need a new clutch from just looking at it. Since the mill scale is gone its a good assumption that it has been over heated. It sure wouldn't hurt to replace it even if that's not your problem
