trenton davis
is it okay if after long rides when i stop and turn everything off the clutch smokes like crazy. should i just put a little water on it to cool it off or what should i do?
Well for one don't ever put water on it. What is your gear ratio, and also how do you ride it? Do you ride mostly full throttle, or half throttle, or how do you ride it? Going slow (low rpms) will cause the clutch to heat up, the clutch locks up when you get to maximum rpm, this allows the clutch to cool down.
rebuild it. I've never even thought about that. but i don't even know the first thing about it I've always just replaced the old ones
