DougRidesMinis
- Messages
- 2
- Reaction score
- 0
So I got this little chopper. I believe it's a Predator brand from it's appearance but I'm not sure. I'm doing quite a few mods but the biggest one is replacing the 49cc engine with a Predator 212. Hopefully the picture I've attached helps. Or that I think I attached..
There are a couple issues so far;
1. The drum brake for rear wheel does not have any internals and I would like to get them. If you have a source or a complete wheel I would really appreciate it.
2. The original motor had the drive on the right side and Predator 212 is on the left. Can I just flip the wheel so the wheel sprocket is on the same side as the Predator sprocket?
3. The sprocket on the rear wheel is a different pitch than the predator sprockets and need to change. Does anyone know a replacement source or part number.
4. What size wheel sprocket would be the right size for the rear wheel with 12 tooth drive sprocket. I want it to boogie but manageable.
Thanks for any and all help.
