jamyers
Got this bone-stock Predator engine that I've had sitting around for years, with not a lot of hours on it. Changed the oil, new spark plug, cleaned the carb (which was pretty funky with dead gas). It's a RuiXing 128, with no idle mixture screw - just a brass plug where other model carbs have screws.
Engine ran pretty well for about 2 hours total over the course of a week. Now it only starts and runs with the choke at 80% on. At that setting it's got tons of power right off idle, but of course won't rev up very much.
I've pulled the carb several times, each time sprayed cleaner through every passage, pulled the (stock .016) low-speed jet, blown cleaner and air through it, even ran a single copper wire strand through to absolutely confirm that it's clear. I've blown cleaner and compressed air forwards and backwards through the idle mixture hole, the transition holes, the main jet, the emulsion tube holes, the air bleeds at the front of the carb, everywhere I can find. I've replaced the gaskets on both sides of the plastic spacer, and looked for cracks or anything that could leak vacuum. With the carb and spacer off, the engine pulls a decent vacuum when cranking.
Still no joy.
I removed the low speed jet entirely and plugged the hole with my finger, and the engine started, idled, and revved (no load) like it's supposed to - without the choke on! Of course, that ain't right, and I'm sure if I capped it off permanently it wouldn't keep working properly.
Every thing I read says "clean the idle passages and the low-speed jet", but for the life of me I can't imagine them being any cleaner...
Ideas?
Still no joy.
Ideas?
