I recently had to build a new frame for my kart. While doing so, I added the Stage I Predator 212 performance kit (header, intake, drilled jet, 18lb springs). I also disassembled my Comet 30 series torque converter and adjusted the springs to the higher torque setting (from the default medium setting). Since getting the kart running again, I've noticed that when I let off wide open throttle, the engine rpms dropping almost acts like an engine brake, in that you can hear the engine sputter some and there is a noticeable "braking" of the kart, even though I am not touching the brake. Now, I don't think it is the engine actually causing this, but the torque converter. I am wondering if when letting off the throttle, the belt is staying engaged at higher rpm, thus literally slowing down the live axle as the engine rpm drops. Maybe that means "something" was not reassembled right? Although, don't know what it could be.
Any ideas (or does this even make sense)?
