I have a Predator 212 minibike equipped with a 30 series Torque Converter, and the governor has been removed. It’s a non-Hemi model.
**Issue:** The tires spring forward aggressively at startup. The only way to keep it stationary is to apply both brakes, which causes the belt and driver to smoke.
**Troubleshooting I've performed:**
- Replaced the throttle cable
- Replaced the carburetor (including the springs)
- Replaced the torque converter
- Sealed leaks around the carburetor and exhaust
- Changed the garter springs
- Replaced the spark plug
- Adjusted the carburetor jetting
- Set the idle to its lowest settings
Can someone help me
Can someone help me
