karte_m0lim
Birds Aren't Real
so , this is another project, main purpose is to reduce any useful job
it's about potato planter I wanna to make .
I have motocultivator (diesel, 10 HP, pict 0 ) and usually plant around 50 kg of potatoes so I was thinking, let's make this easier.
made a small plough (pict 1) , have 20 cm diameter wheel, plastic pipe (7,5 cm diameter).
so idea is to put one potato on top of pipe, and when impulse from attached wheel is there, flap is opened, and potato is planted
well, wheel is 20 cm in diameter and circumference of cca 60 cm so in one revolution, I have to have two impulse ..
i was thinking to attach lever directly from wheel to flap, put wheel have to have free movement up and down to follow terrain and that movement can open flap. (pict 2).
next solution is use shielded cable , and again attached directly to te wheel. I don't know will cable be able to sustain that twisting. (pict 3)
3th idea is to use two excenter , cable with pin on the end and spring to fore tension. Problem could be force of spring, as wheel is small and light, it could block wheel. (pict 4)
last idea is to use sprocket and chain . with that solution, I could use bigger and heavier wheel and with right ratio achieve wanted impulse. From sprocket 2 I could use lever to attach flap.
on pict 6, well picture say for itself, is idea to avoid constant movement of flap. option also is to use solution form pict 3
thoughts, ideas, free potato planter to my address, anything is welcome ...
