Hi Guys,
I'm wanting to install these on my offroad go kart which has a 228 small block. I see there are crank shaft adapters to go from 3/4 to 1 inch. Then there is an adapter from 1 inch to the 30mm tapered that the Polaris CVT uses.
That would be a really quick and cheap way to do this instead of having a machine shop fab it into 1 adapter. I'm just wondering if that would be 1 too many adapters?
Do these adapters handle decent power? I think I'm around the 17hp mark.
I have a Comet 30 CVT but it is limiting me to around 4000rpm and my engine will spin to 7000 safely. I could get the juggernaut but I would still not have reverse, which I would like. I also have a Polaris quad with this CVT and trans and it is well made and over built. Plus you can pick them up for a reasonable cost.
