anderkart
Pics of a mechanical Chevy fuel pump on a Race Kart
Yesterday at the races I ran across this kart that has a Chevy fuel pump that operates off an axle mounted eccentric that'd been custom machined. I just thought some of you hard core DIY'ers enjoy seeing these pics:
The owner claimed the eccentric was designed with a fairly low amount of lift to only produce about 1 PSI of fuel pressure but it still had plenty volume to supply the Tillotson carb. These carbs dont have a float bowl and the pump obviously wont work until the axle is turning but the kart was direct drive so the highly modified flathead Tecumseh motor fired right up and ran great when push-started.
He had the pump mounted to the caliper with a prety beefy looking Aluminum bracket they'd made up. He cleaned off and re-greased the eccentric between each race. He could of achieved the same results with a $20 Pulse Pump but I just thought the whole concept was toataly ingenious.
(although using a set-screw instead of those wire ties woulda been a nice finishing touch)
