Is there another brand which makes the same model.
Someone changed a few parts and now I can't find OEM parts.
the front hubs are gone the ones I found on amazon and ebay are close but too long and I can only get the nut a few turns. With some lock tight it will work for now but I would like something that works
They also changed the front wheels which fit but they are the 110cc ATV wheels with brake drums. the hubs dont fit the 15mm spindle. The new hubs did match the bolt pattern but too long IF I could find replacement bearing to fit the brake drum/hubs I could use those they could work.
Most other parts are typical. still have not seen parts diagram with part numbers.
