Girl-Trapped
Howdy, Y'all!
So we've been driving the Yerf Dog lately (when it's not raining, anyway) and I finally got around to rebuilding the carb and getting the best idle the kart's ever had. The only other issue I usually have is that my jackshaft/axle/30-series pulleys are a little off as far as alignment--it's always been wonky but I shimmed it on one side and it's also better than it's been.
All of that to say that I pulled the kart out yesterday and after a couple of training laps in my neighborhood with some friends, I pulled into my driveway, the motor went to idle, and then died with more gusto (or if you're a fan of the Breakfast Club, more RUCKUS!) than usual--not unexpected given the rain we've had and I hadn't cleaned the drive clutch up so it was a little grabby.
That's it--would NOT restart. Plus gives me a slightly noticeable kickback. Doesn't even try to start, sort of like the kill switch is on. Did some searching online and on this site regarding a sheared flywheel key and the symptoms I've read about seem to fit what's happening. The rocker on the flywheel side of the engine seems to have a lot of play in it unless it's engaging that valve, otherwise pretty floppy. The flywheel key is not sheared completely, but is it sheared enough to cause the problems I'm describing? See pics below. . .
Thanks!
Thanks!
