G.W
Your point is valid and has changed my mind. The stamped steel is what I will go with. I put some high temp wheel bearing grease on that shaft and it seems to work great.If the “stamped steel” plate is like mine, its plenty heavy duty. 3/16 steel, l believe. No l’m not runnung out to measure right now. I personally prefer steel over aluminum.
lts a lot easier to weld if necessary. The stamped part is only some “ ribs” for rigidity.
Btw put some oil on the spinny thing that yer drill attches to.
