r_chez_08
Should be in the shop...
OK, theres this new guy at school who seems pretty cool, same interests as me and stuff.
Anyway, he said he had made NO2 before from ice packs. Dunno quite how but he knows the method.
Since I have a go kart, we figured- why not just as a one off for the lols and a bit of an experiment. Mainly just to say we did Dont really care if it works or not, just something to do!!!
The engine is a 6.5 clone, beefed up a litte (i.e. rod and flywheel, upped compression, bored carb, rejetted, header, mild cam, ratio rockers and a few other bits)
Our first issue was how to compress the NO2. We figured some form of vacuum pump, and pump it into an old fire extinguisher or something?!
Then our issue was how to control the NO2. Maybe a small valve or something by the driver, and then putting a pipe in where the choke lever pivots (i.e. direct feed into the carb.)
Now even if we did manage to get the first two things right, does NO2 require a richer mixture because of the added oxygen? If so, maybe we could rig up a small venturi setup and a fuel source inline the hose supplying the NO2?
Are we completely barmy, or should we go for it?!?
Cheers guys,
Rob
Cheers guys,
Rob
