Hey all. New here to the forum. I'm excited to start reading and learning as much as I can from many more experience people than myself. This is my first project...heck I don't even own a welder yet. So, there is a lot of learning and discovery going on. I'd like to explain the build my son and I have been designing on paper so far and see if I could get some help with some newbie questions, so if you have time to answer, talk to me like a 3 year old so I can follow Thanks in advance!!!
Speed controller: packaged with motor
Sprocket / gears: 11 tooth : 54 tooth
Battery (option 1): 72v 40ah 0-3000W Lithium Ion
or
Battery (option 2): 12v 8ah (x6) 0-3000W rechargeable SLA Neptune
Tire size: 12.75” diameter total
2) Is the battery / motor combination going to work? Am I missing something there?
3) Does the speed controller do what a solenoid would otherwise do or do I need both?
4) Battery connection wire gauge? I was thinking 6 gauge..is that overkill?
5) will 1" conduit will be robust enough for a frame? I think with enough bracing it could, but want other opinions.
6) does anyone know of a good step by step guide to building one of these? otherwise, I'm gonna wing it haha.
Thanks again! Can't wait to hear from you all.
GOALS:
- Quiet
- Cart weight with batt (150lbs) and carry me (200lbs) for total carry weight of (350 lbs)
- 35mph
- 30 min drive time
Performance Parts list:
Motor: 72V 3000 watt brushless DC 6500rpm max This motor and ESCSpeed controller: packaged with motor
or
Questions:
1) Is my gear ratio correct for a slightly Gear ratio correct for slightly higher speed? I want more speed than torque..2) Is the battery / motor combination going to work? Am I missing something there?
