Sdannenberg3
Semi-Effective Member
Hey, so I am going to need to do some modifications to my go kart frame. Th metal is no more than 1/8" thick but i also am going to be needing to weld tubular frame together. So would a flux welder work in my application or should I stick with an arc welder because dont they leave bigger, stronger beads? But a flux welder seems like it would be nicer to use. What about this welder?
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=55525
It says it does both gas and gasless operations? does that mean that you start the welding the same way? by touching the metal and making an arc? Im really confused with this stuff people. Could anyone enlighten me on what I need to get in my situation?
