I recently bought a 48 Volt, 1800 Watt, DC, electric motor, controller and charger. I've been getting the kart ready to go electric and decided to test the motor today. I charged the 48V Li-Ion 48 V battery, hooked up all wires from the battery and motor to the controller and gave it a try. Nothing. No hum, no movement, nothing. The controller has a black wire and red wire to connect to the battery plus a yellow wire, a green wire and a blue wire that connect to the motor and a 5 wire push plug that connects to the controller as well.
There are a variety of other wires coming from the controller that are labeled brake, reverse, throttle, brakes (2), 3 speeds, brake lamp, electric lock, indicator light and charging port.
I am trying to learn how to direct wire the motor to test it (if possible) and avoid going through the controller. Does anyone know how I would do this or can someone suggest how I might try to deduce why the motor isn't working?
Thank you
Thank you
