NEED HELP IDENTIFYING
TeamMuir
Guys I bought this from only 1 picture off of facebook...
I haven't a clue who the manufacturer is or if I can get parts.... any help would be much appreciated...
I do know that a new 420cc predator motor has been installed and runs decent ( sounding / starting ).... but needs a torque converter belt..
Which I don't know we're to buy.....
Guide me if possible....
I'm planning on buying seat provided it measures up to fit will see a bit later today...
Gokart Supply website has all the information you need about belts and how to measure for them. What you have for a CVT is a 30 series TAV II !!! Buy only a Genuine Comet Belt!!! The cheap belts are made from yak grease, vinyl, hair and rice fibers. It takes only minutes to burn through one. The Comet will last a year or more. Also while you are there you can read about the care and feeding of the 30 series also.
Denny is right!
I think the seller was lying or ignorant, that looks like a Predator 224 to me. If it had a 420 it would have a 40 series TC, and denny knows what he's talking about, that's a 30 series TC
You can get a 30 series torque converter to go on a 420. A 30 series 1" driver .
But it looks like a 224 to me also. The red fan shroud and the fact that there is no starter motor, or even a boss to hold one cast into the front of the block tells me for sure it's not a 420. Either way, a 224 with a torque converter will give you plenty. And yes, spend the extra money for the comet belt.
I learn something new every day.
OP, you will probably have to clean that TC. Denny or Pancho could tell you how.
