Need a tube. Tire is marked 10x5.50-6
DonutHands
The tube also needs an angled stem.
Anyone know where to find such a thing? Or what size would be compatible and where to buy?
Kent
Willits, California (Northern California)
https://www.gopowersports.com/410-6-tube-90-degree-valve-stem/
I think this works for you. I'm not sure how the "410" compares to your 10" but I think it's pretty close to the same. Most tubes will work for a range of tires, they just need to be close on that first number in the size. Otherwise you can do a search on line for that size tube or search Amazon both will probably get you what you want. Good luck.......
DonutHands
Found these that match the front tire size
https://www.monsterscooterparts.com...4-50-6-inner-tube-with-angled-valve-stem.html
The fronts are marked 10x4.50-6 and the rears are 10x5.50-6
Would Kent's recommendation or the link above be a better option?
https://www.monsterscooterparts.com/10x5-50-6-rear-tire-and-tube-for-minimoto-go-kart.html
maybe this site sells the tube alone.........you could check with them
Found those as well. Marked as 'discontinued' but couldn't hurt to ask them.
The tubes for the same Minimoto kart that is referenced on that page. It's a **** shame they chose some oddball tire size for this thing.
DonutHands
Donut
Make sure what you buy is the right size for your 6" rim. The last number in the size indicates the rim size. Looks like monsterscooter has what you need.
Sorry, yea, I deleted my post that had the ebay link as i realized that i had the last number incorrect.
If Monsterscooter does not have the 10x5.50-6 size, ill just order up the 10x4.50-6 size and hope for the best.
Kent
That first link I sent you to gopowersports tube does not look right for your tire. I just looked at the description (further down the page) and it says it's for a 410-3.50-6. I think the 350 is width. The tube you found at monster is 4.50. and I think that would work in your 5.50 tire. They show a contact phone number maybe they could advise you.
