narrowing rims
Thanks for your responses. Yes, I do have a lathe and have already dismounted the tires (made my own tire removal tool) and proceeded to cut the rim halves apart. I also have TIG and MIG aluminum welders. One rim half is 3 1/2" and the other is 5" for an 8 1/2" rim.
My main concern was due to the rim taper. If I cut out 2" from the 5" half, I don't think the remaining pieces will be close enough in size to weld. Will probably go ahead and cut them and see how the remaining parts fit together. If I can't get good alignment, I can always just order a couple of VanK 2 1/2" rim halves and weld them to my 3 1/2" to make up 6".
