r_chez_08
Should be in the shop...
DONE!!!
However the sprocket broke
you should reinforce your steering, "C" brackets, spindles, and tie rods.when the spring compresses it looks like it will hit the rim or tire,
you have all that spring but not alot of area to let it compress.
I have ordered another 3/4" pillow block bearing for £7. Will fit it up so that it is just next to the sprocket (up to 1" away)Boy, you really did taco that jackshaft, didn't you! You certainly want to avoid cross-drilling it. But I would still suggest adding a support bearing close to the sprocket. Even with a wee bit of chain tension, you might be surprised at how much it can flex.
The entire spindle assembly moves with the rim. It will remain that distance from the wheel throughout suspension travel. It does look like it will though.
I didI see now that you used forward facing spindle arms (pitman arms?) rather than backward. Did you incorporate Ackerman?
