I'm building my first go-kart and have been reading as much as possible to make the best choices I can for my own goals. This forum and its members have been an incredible resource to that end.
For space and weight reasons (not to mention cost), I'm using 20Ah batteries (https://cdn.shopify.com/s/files/1/2364/9089/files/EXP12200-Specs.pdf). I realize the unfortunate limitations this may give me in run time but have come to terms with that. To mitigate current draw with a bit more performance, I've opted for a 72V setup, though.
I'm now between two different motor configurations: either an MY1020-style 3000W with a paired 50A controller (https://www.amazon.com/gp/product/B07KR2FN89) or the Golden 3kW (HPM3000B) with a Kelly KLS-S controller. Obviously the Golden setup will be more expensive than the MY1020, but it's far better quality/performance, so that might be worth it to me if I can get away with it.
My concern is the current draw on the 20Ah batteries. I'm having a hard time finding reliable information about max discharge rates on AGM batteries. It seems like ~2C for the MY1020 should be tolerable, but beyond that, I'm not as confident. The 72V Golden 3kW could draw ~4C from my battery setup. This leads me to a few questions:
Let me know your thoughts. I appreciate any info you can provide. And be gentle - I'm still trying to learn.
Thanks!
- Is a 4C draw okay for, say, 20-second bursts on a 10% duty cycle?
- Will AGM batteries supply whatever is asked of them as long as temperature and 50% discharge limits are respected?
- Are there rules of thumb to abide by when sizing motors with batteries? (and are these rules based on science?)
Thanks!
