cheap_thrills
Anybody with an American Express, care to drop a picture looking down over their front suspension? I just picked up this AE frame about 2 weeks ago, and started taking a closer look at it, and it appears it had been repair at one time but the frame's "caster" is different from side to side. One side sits a bit negative, and the other is nearly straight up and down. I have no problem cutting, correcting, and rewelding the frame. I'm just trying to find out which side is correct to go off of. Thanks everyone!
*UPDATE* there is a reinforcement plate that was welded under the RH side, but the LH side appears it has been ground on or cut on, at some point in time also.
