adrenaline406
- Messages
- 9
- Reaction score
- 0
I know this has been gone over several times: adding a charging system to a kart. We all see that alternators are too parasitic for most of us (I am only 7hp stock), and running a battery to be recharged is just too simple, and I would prefer not to have to charge before I go out for a run. If your next question is "Do you really run it at night all that often?" That is the only time my friends and I run it.
Question Time:
1) Why don't people add charging circuits more often? It doesn't seem too cost prohibitive.
There's a magnetic flywheel on ebay for $20 (maybe I could add some magnets to my flywheel).
There's a stator also for $20 on ebay, I would have to check the bolt pattern.
There's a 3 wire rectifier on amazon for $30 shipped.
You can find a small trailer brake battery for $20-30.
Beyond that I already have all the wiring/lights/switches/etc, Is there something that I'm missing on the parts list?
2) My block has a bolt pattern for the stator already there, it is 2 7/8" by 4. Is that a standard size across the industry or might that be specific to a manufacturer?
3) Being that the coils are on the inside of the magnetic field, these systems do produce AC as an alternator and would therefore require a rectifier?
(I'm sure there's more)
Thanks in advance.
Question Time:
Thanks in advance.
