lights from coil? with regulator?
ezdasnowman
south florida
so i was wondering if i could use the power from the kill switch wire along with a voltage regulator to power 1 light...? any thoughts, i'm not trying to put a alternator on my engine, if ii have to maybe a small battery ....
solomon
ca
i would imagine it would effect timing and hurt power, have you checked voltage with a multi meter? i would use 1 of those mini generator things, i forget what they are called but they generate electricity and are tiny
solomon
ca
i figured this was a bike or something because, i know some bikes run headlights off the coil.. What engine are you actually speaking of?
sideways
Unfinished projects king.
Perth, Western Australia
I think he's meaning from the ignition coil on an industrial engine, if so, it will not work. As EagleTalons says, connecting it to the kill switch wire would ground the coil and kill the spark. besides, I doubt it would generate enough electricity to power anything but the ignition system.
Hayden
Kaptain Krunch
Pro Junk Collector
vermont
Your thinking of CDI ignition, where there is a Stator (coil, normally under flywheel, sometimes outside), which powers the CDI, and ignition coil. The power is always taken from the stator, not the ignition coil.
Kenny_McCormic
Kartless....
Michigan Troll
The stator has separate coils for lights and ignition, the ignition coil is much smaller and finer, so it makes good power at very low RPM(if the coil ran on the main stator you would most likely need a battery). This is not always true however, I have push started a VW powered sandrail with a completely dead battery.
Kaptain Krunch
Pro Junk Collector
vermont
good point, stators are almost always dual coil, or more. My kz400 engine uses the same coil for ignition and power i think, however it has points and a battery.
solomon
ca
I had a 66 Yamaha Trail Master 100 that ran lights off the coil or stator. Too bad its at the junkyard =P
EagleTalons
Master JB Welder
Forsyth, Montana
VW use generators instead of alternators. So they can use dead batteries and not damage the generator. Unlike using an alternator with a dead battery.
Most VW engines used a Generator. Newer old models started using high output alternators.
