Last 2 cycle Lawn-Boys have exhaust routed to top of deck.
All 2 cycle models previous to Duraforce had exhaust coming out of underside of deck.
I suspect that directing exhaust down into the ground made them (somewhat) quieter as well as making them less expensive to manufacture. Direct with no plumbing.
The jump in HP (muffler size/design?) may also have been a contributing factor. Duraforce equipped mowers are very much easier to work on because of the new plumbing.
@crazycart: Get a new exhaust flange and gasket, otherwise it will leak. Crank seals (both) must also be changed. Just a heads-up. I'm sure you probably already knew this.
