Role
Nobility
Just bought this kart it's a much bigger kart than I have seen in a while. Only one I have seen of comparable size is a Tomberline Crossfire that I had at one time.
Guy that I purchased it from gave me brief history on it.
Kart was his wife's and her father had bought it for her a few years ago. She got to where she never rode it anymore and it sat for a while. A close friend of theirs said he could fix it and took little bits here and there off of the kart and left it. Worse than I thought, when I say "left it" literally with carb off oil cap off, gas cap off .. You get the picture.
1. I knew where the biggest problems would lie. I started with the gas tank. Removed little particles of rust with apple cider vinegar and BBs, shaking vigorously for long periods of time and rinsing with distilled water. Repeated this process over the course of 2 days. Gas tank is good now.
2. The peacock valve under tank was broken off so I wen to local hardware store and got a new setup. Basically it's just a gravity feed now. Bought a new inline gas filter also.
3. Took my air hose and lightly sprayed out the oil casing with the oil plug off. It was some sludge to say the least. Following that I filled it back up with oil.
4. Cleaned the carburetor (3 times now) vigorously. Everything off the carb, main jet, pilot jet, diamonds inside choke chamber with copper wire, air screw hole, etc. Went through 3 bottles of carb and choke cleaner to make sure I got everything.
5. Checked all the wiring, spark plug coil, changed spark plug to an NGK C7HSA and set the gap to .025" inches.
6. Put a new battery on the kart (did not have one on it)
7. Drilled out the key hole because he didn't give me a key and I like the universal feel of any key, haha.
8. After several attempts to start it and looking for vacuum leaks because I felt either not enough air or either not enough gas was causing the issue. When I went to start it and would let it sit for about 5 mins, I would come back and it would fire up, but I would have to have my foot full throttle and then after 5 secs or so it would die out.
9. Finally got it cranked enough to get it moving and went around my block one time. While driving it I kept it full throttle and noticed I was moving about 10-15 mph. The engine wasn't reving high at all, it was limited. Hydraulic brakes and e-brake weren't riding the rotors either. No slipping on the cvt either, it was smooth the whole time, just limited rpm.
My idea was to get the engine warm enough to then adjust the idle and fuel. I also wanted to cycle the oil in the motor with it being warm to cycle any missing debris or sludge that was left behind.
After this short ride today I pulled it back in the garage and immediately when I let my foot off the gas it immediately died.
10. While the engine was a little warm I waited about 10 minutes and then drained all the oil that cycled through it out.
11. Put fresh oil in it and this time I used Marvels Mystery Oil to substitute 20% of the oil. So I did around 700ml of 10-40w SAE Pennzoil and then did 200ml of Mystery oil.
12. I then put a half a tank of gas in it. Gas was mixed with mystery oil and some seafoam for good measure and to help with the ethanol and carb deposits.
The only thing that I can think of at this point is one of three things.
1. Carburetor - however, I've cleaned quite a few in my day and I ultimately don't think that's it.
2. Valve adjustment.. Seeing as how they apparently left the kart to die and women maintaining anything is usually not the case, I doubt the valves have ever been adjusted.
3. Piston / Rings could be bad - but I question this some because the cruise around the block today was not at all jerky or knocking, just limited engine and RPM feeling.
Anyone want to help me narrow this down?
Few things that would be helpful:
1. Type of kart? So I can locate a service manual
2. If valves need adjusting I don't know what to adjust it to.
3. I've looked around on various sites for this model and can't find it.. I noticed the rear axle is different from most I've seen, it's all built into the casing of the motor both ways, you can't even see any axle. Has turn signals, low/high beam, 4 DISC BRAKES w/ e-brake, dual horns, rear view mirror, and 12v charger port built into dash. Don't see a gearbox for reverse or anything, unless it did at one time and was taken off.
I did notice when I had the rear end jacked up off the ground, when rotating one wheel a direction would cause the other to spin the opposite direction.
Anyway, I'm ready to knock this out and finish this project up, my little boy has been wanting to cruise in it since I got it.
Any help would be appreciated, thanks guys and gals.
-Role
-Role
