karl
So I ordered this new fancy clutch to try out,
The rig is a monster moto 212, stock motor , mods are
230-0211 NR Marine grind cam
10.8lb trick springs
4 degrees advance
Re-jet
Better flowing exhaust
Governor turned to 4500rpm
I installed the new clutch, new 203590 belt, and yellow spring in the driven unit, and took off.
Launch was softer, then motor reved up high, hits governor, and the belt is still in low ratio, stuck going slow
So I put the factory red spring back in the driven, and same results, belt wont ramp up more than halfway in the driver. Motor revs up to gov right away, and you go nowhere.
I put the factory 30 series driver back on, same belt, and the bike picks the front tire up on launch and shifts right, and pulls hard to full top speed.
So what Am I doing wrong? Based on what gopowersports said, I was under the impression it would at least work, with a lightly modded engine.
Thoughts?
4 degrees advance
Re-jet
Thoughts?
