Preduhtor_122
- Messages
- 23
- Reaction score
- 1
I recently put a predator 212 engine on a coleman BT200x. I installed stage 1 and 2 performance parts (new air intake, header, billet connecting rod, billet flywheel, 18 lb valve springs, .038 performance jet, govenor removed, Hot265 cam) It has the stock sprockets and is using a max torque clutch. I’ve seen videos of people getting up to 45-50 mph from this build yet I only get 35 to 38 if I’m lucky. Also if I run it full throttle for over about 15 seconds the engine dies out and is hard to turn back on.i also purchased a Mikuni 22mm carb and when I use Thag carb the engines starts sputtering and dying out close to full throttle Any thoughts?
