So I get this email today. Often people email me direct but I always suggest they ask questions in our forums so everyone gets to see the answer.
Anyhoo, email reads:
Hello
my name is Hayden and as a school project i have decided to build a mini chopper i was wondering if you had a list of parts i will need ?
i would greatly appreciate it if this is possible
thankyou
And I think that it's probably overdue. Now, if you've spent time working on these projects you already know that you need the handlegrip throttle kit (plus the cable!) and what not..
But Hayden's right, we could use a few more good "lists" to help out the how-to / tutorial idea suggested back here
So I'll go first, this shouldn't take too long I think.
Engine System:
Engine 3-6.5 HP
Centrifugal clutch or Torque convertor
Chain (sized at #35 or #40-#42 pitch)
Rear sprocket 60 or 72 tooth sized same as chain.
Controls:
Handle grip throttle control
Throttle cable
Wire stops
Method to hook throttle cable to engine (may need a kit)
Brake lever or foot pedal
Brake cable
Brake (possibilities are many, elaborate on this below)
Wheels and Tires:
Choices are many. Maybe have some discussion about the choices .... 4 pattern bolt hole vs 2 13/16"
Axle choices
Hubs plus bearings / Live axle with pillow block
FRAME!
Build or buy discussion
OK so clearly it's not perfectly straight-forward. Maybe from here we can flesh out that starter list, and discuss why you'd choose certain choices vs. another choice (live axle vs fixed) etc. If the threads get too off track we'll just create new ones and keep going.
Thanks!
Hello
thankyou
Engine System:
Engine 3-6.5 HP
Controls:
Throttle cable
Wire stops
Brake cable
Wheels and Tires:
Axle choices
FRAME!
Thanks!
