Hood Billy Snapper Rat Mower
Budget GoKart
Aka a kenbar
roachdale, indiana
Rat snapper junk mower
First off there are no hills where I live so it's gonna be hood Billy and my buddy's shop who might help out is called hood billy fabrication. Also this thing had rats living in it has two good tires and I have most parts that work with it. Just gonna rat rod the crap out of it. I have plans of using some of the empty frame space to either shorten it or move the engine back for a mid engined look. But I could use it to make the steering more go kart like. Also it has hiem joint steering instead of ball joint steering. Thanks to Jhoppe for driving an hour to trade!
J.S.@SMS
Road Hazard
Weeki Wachee Fl.
Are you going to mod that engine, or put on a different one. Personally, if I had that engine, I'd keep it maintained but stock, and use it on my mower, instead of modifying it. The only problems those opposed briggs engines usually have is, like every single small engine ever produced, the carburetor getting clogged up.
I'd look for a briggs model 28, they're often used in mower racing. And a plus side of the model 28 is billet rods, cranks and flywheels. Of course arcracing also makes rods and flywheels for the model 42 and 46 opposed twin engines.
Budget GoKart
Aka a kenbar
roachdale, indiana
probably just a better intake as in scoop and straight pipes but yes i plan on keeping this engine on here and mostly stock. also i have a briggs 20hp vtwin on my mtd
Oppys are nice. So I get your plans, but more details would be greatly helpful. Are you keeping the transaxle on the tractor or you switching to a live axle? Just keep in mind, if you are doing a live axle swap, I'd suggest either a 1:1 or 2:1 right angle gearbox. Doc Sprocket's Diesel Weasel is a riot of a build. It's kind of T-bucket rat rod mower, but really well done.
Budget GoKart
Aka a kenbar
roachdale, indiana
Current plans are just keep the transaxel and pulley swap basics but if this guy does indeed trade me I might get a weird looking mower with a live axel and a right angle gear box already I'll try to find some pictures but it's really weird looking. Also I take heavy inspiration from doc sprockets build that thing is insane!
Budget GoKart
Aka a kenbar
roachdale, indiana
Plans changed with this thing im using a differental live axel from a montgomery ward that was beat to a pulp. I also have a three speed gear box with reverse. I think i might try to fit the 11hp briggs on the frame too because the opposed briggs mount is different. It probabaly wont fit but worth a try. Also the axel mounts are super flimsy who cares lol. It isnt goung that fast anyway.
Budget GoKart
Aka a kenbar
roachdale, indiana
So made some changes took the opposed briggs off for now and put this briggs on that was just going to rot into the ground. I got it with a gear box and axel from a montgomery ward. Not a good one either. It ran after i put a pulley on and some gas. Spark is too good lol it nearly blew my finger off while trying to kill the engine. Heres the numbers if someone could get some info on it and some pictures.
JTSpeedDemon
2019 Build Off Winner!
Texas
17 Ci (roughly 7 HP)
0 design series
7 vertical crankshaft, Flo-Jet (I'm almost certain it's the one piece FJ)
0 plain bearing, DU/non-flange mount, splash lube
2 rewind starter
And it was built on February 12th, 1970.
:cheers2:
Budget GoKart
Aka a kenbar
roachdale, indiana
Not mine its my brothers it was marked stolen by the first owner who sold it so he could get insurance money then my brother bought it from a dude who was restoring it before he found out it was marked stolen. Then my brother found out about it. Dont buy motorcycles from facebook market place lol. He plans on getting it running this summer though.
Edit:sorry bout the sideways pic my phone has the stupid.
Budget GoKart
Aka a kenbar
roachdale, indiana
Ready to go i need to start it. And it still doesnt have a steering wheel and the rear end is not moving i think its lock is engaged
Update : it runs and moves no steering wheel though cant drive it till then the lock was engaged thoug
