Home made shifter kart
ed1380
Banned
ATL, GA
I scored a xt70 motor from the scrapyard, so what better way to use it than put it in a kart. 6hp with 3 speed isn't going to break any records, but it should still be fun.
I spent the last few nights coming up with a design. Just a simple ladder frame. The design will change a little depending on what parts I find.
Caster is fixed at 20*, but camber is adjustable. 3/8 hardware should be plenty strong.
It's definitely a work in progress and I'm all ears for tips and suggestions.
Im not too sure of the motor, but a quick search kinda shows that its left side drive, so your brake rotor and sprocket will have to move aswell as the center mount bearing.
Over all it looks good.
ed1380
Banned
ATL, GA
I found some time to work on it a bit more. Using 10" tires was wrong to begin with. Seat had to be offset 2.5" in order to have equal right-left balance. With a cone filter and 6" straight pipe the motor should breath
